Hid Kit (one bulb not working)
to those with an aftermarket HID kit in their vehicles, can you please advise if you need to replace the whole kit when one bulb is "dead" or can you just get a replacement bulb
my son's car has a 9006 lowbeam hid kit and one bulb won't turn on
thank you!
thank you!
If you can isolate the problem to be the bultb, then you should just replace the bulb. You can just purchase one new bulb. Try eBay or the place where you originally purchased the HID kit.
-Brian.
-Brian.
Swap bulbs and see if that one side still doesn't work. No light = bad ballast and/or ignitor (depending on ballast design). Double check the wiring too,
Thanks!
car is at the installer's shop right now
wiring, ballast and swapping of bulbs from one side to the other are being done to find out exactly what is "defective"
thanks for all your tips!
