Hid's
I'm looking to get a set of HID's for my 97 SC 300. what brands are you guys using? where did you buy them? I'm looking at sets on ebay but not sure what i should stay away from. any info would help. Thanks
AFter much research from searching on this site and HIDforums.com
Which kit for the SC?
Philips 6000 K kit.
How much?
$500
Where?
www.kmimports.com
Ken will fix you up.
30mins installing and you are ready to go!
BIGd
Philips 6000 K kit.
How much?
$500
Where?
www.kmimports.com
BIGd
O.C. Lucky Strike Fanatic
Philips 6000 K kit.
How much?
$500
Where?
www.kmimports.com
BIGd
Philips 6000 K kit.
How much?
$500
Where?
www.kmimports.com
BIGd
-Bryan
Originally posted by LexAristo
Email Ken @ sales@kwimports.com. When you "Bryan" referred you, he will only charge you 475.00. Hope that helped.
-Bryan
-Bryan
Originally posted by siniquezu
For that much, you can retrofit...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
if i get plug and play, will i hafta worry about glare or the cut off? i drive an rx300 and was considering a plug and play kit but after reading about some drawbacks, i'm starting to wonder...
Time + money will be over 500. Plug and play is more complete and takes less than 20 min to install. Also retrofitting means de-linging your headlights.
I have a RX300 with aftermarket HID's from autolamps and all I had to do was aim the lights a little lower. I'm very satisfied with them. I will admit that sometimes I think about it and wonder if I should have gone for a projector retrofit. Due to the time involved in having to send them out to be retrofitted, I decided to go with aftermarket HID's.
J
J
you got any pics?
J
J
also a retrofit will be 50% brighters than kits usually because the projectors are made for the HID bulb, and you will also have perfect cutoff line and perfect light ditrubution with no glare/blackspots.
