Foglight bulb removal
On the ES, you have to get yourself under the front bumper of the car and open up the plastic splash guard to access the fog light bulbs. The splash guard are held by 10mm bolts I believe. Once the guard is opened up and you see the wiring for the fog light bulbs, pull out the electrical connector from each of the bulbs and remove the bulbs.
Reverse the steps mentioned above for installation of new bulbs. Be sure to wear rubber or latex gloves when handling new bulbs as you don't want to touch the glass part of the bulb. Hope this info helps.
