Size of projector
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
What size is the projector in our sc300/400s? The reason im wondering is because i plan on retrofitting some other projectors into the stock housing and if they are the same size, it would be much easier.
Thanks,
Tom
Gotboost0612@aol.com
Thanks,
Tom
Here are the deminsion for the SC430 projector. They are also very close in size to bosch, s2k and A6 projectors. They give off less color than these others but have a wider beam pattern.
lens diameter = around 60mm (maybe 1 or 2mm less)
length (from lens to end w/D2S bulb and HID plug in place) = 170mm
max width (bowl dimensions only) = 90mm
max height (bowl dimensions only = 75mm
Give or take a few millimeters.
sc400 was around 90 mm if I remember correctly
