What Kind Of Bulbs Are These??
HI,
I AM INTERESTED IN CHANGING ALL MY BULBS ON MY CAR TO GET THIS LOOK, I HAVE POSTED A PICK OF 2 CARS I WANT ALL LIGHTS TO LOOK LIKE CAR #2!
IF SOME ONE CAN HELP IT WOULD BE GREAT ALSO WHAT ARE THE STOCK COLOR/KIND OF BULBS?
THANKS
THANKS
Looks like he upgraded the lowbeam stock 4300k bulbs to the whiter 6000k bulb. He also switched that fugly blue M4 wedges to the Polarg M4. I know it's not LEDs coz the color is not as white.
He also probably upgraded the stock foglamps with a 9006 HID kit. Good luck.
exclusive matchup
the headlights maybe stock maybe 6000k, hard to say coz' two different picturs so different color
the night time housing, i say it's either polarg m4 or m6. m6 is brighter but harder to install
the fogs, if you have yellow fogs, you need to take out the fogs and break the yellow lens inside, that's what causing the yellow. you need to replace the bulbs too. if it's stock hid headlight, then you can get some superwhite 9006 and it will match well. but if you have 6000k hid headlights, and want to match up the fogs, you need to get 6000k hid kits
read the stickies for more info
please dont take this the wrong way But,....i dont quite understand ! {i'm a woman if that explains anything}
where would the "M4 wedges or polarg m4" be located at? and what are HiD's and LeD's and which are stock?
also it would probably help if i knew the name for each part of the lighting system because i'm not even sure which lights are which so that would probably help me first...i have included a pick just name the parts listed please!!!
and last cant i just change all the bulbs on the headlights to white?
thanks....
exclusive matchup
thanks....
thanks....
1 - headlight (if you have hid, that's d2r. if you don't, that's 9006)
2 - high beam (9006)
3 - parking light (wedge bulb type 194. if you get polarg replacement it's m4)
4 - fog light (9005)
Master Thread Closer!!
Originally posted by rominl
hhahaa, ok, let's try it again
#2 High Beam is (9005) and #4 fog light is (9006).
Pete
panda_ek9
12-25-08 12:40 AM
