RE: H.I.D. Installation -MANARAY HELP!!
I was wondering if anyone has instructions to install H.I.D. kits. Specifically a 5000k/Depo - Xenon H.I.D. kit. Generally speaking, are most H.I.D. kits installation very similar?
Manaray, can you help me out with some specific instructions please. I was told you were the man to talk to on the forums!
Thanks
Chris
Thanks
Chris
Manaray has almost disappeared.
As for those HID kits, plug the bulbs in, plug their wires in, tap into the low beams, and tap into the battery and you're done. It is a plug and play and is very simple. If you're in the Socal area, I could help you out. If you're in the the norcal area, I''m sure Rominl can help too.
Master Thread Closer!!
Manarays is like the wheel guru....Rominl is the lighting guru.
Are there NOT instructions? Most kits are pretty simple to install. Where or what part of the install are you having problems with?
Pete
Pete
exclusive matchup
Pete
Pete
i remember there has been at lesat 2 to 3 times people posted instructions, so it shouldn't be hard
drewefx
10-30-07 06:37 PM
