H4 Hi/Low kit for 95 LS. Any benefits ?
Hi,
I have idea to replace my factory lights with HID system and I have few questions:
1) Is it a good idea to install Hi/Low kit or Low is enough ?
2) Price/benefits - worth it or not ?
3) What system/producer is a good one ?
4) Light type must be d2s ?
5) Do I have to replace my light assembly with clear ones or not ?
6) Autoleveling ? Do I need it ?
Thanks
Thanks
Hi/low kits are very prone to glare because the motor that shifts it may get damaged. I don't think it's worth it.
HID kits in general have more glare than OEM applications. The light bulb and light assembly depends on your application. Because of the shifting, you will either need to align it REALLY well IF the kit allows you. if not, you need the autoleveling kit but good luck with the workload of wiring.
Thank you for reply.
I had another look at my headlight assembly and I noticed 2 (!!!) bulbs there. Manual says I have h4 assebly but what second bulb is doing there ???
