xenon hid headlamps
Old 08-26-04, 12:20 AM
tee429
tee429's Avatar
Post xenon hid headlamps
What's the closest HID kit color to the factory HID? 8000k bulbs or 10000k bulbs?
Old 08-26-04, 12:22 AM
rominl
exclusive matchup
rominl's Avatar
4100k...
Old 08-26-04, 01:22 AM
tee429
tee429's Avatar
Default hid xenon headlamps
romin1, so even the 2004 lexus with the hid xenon option comes with only 4100k?
Old 08-26-04, 01:44 AM
Neo
The One
Neo's Avatar
Default Re: hid xenon headlamps
All factory (including Lexus) HIDs are 4100k. I've actually seen bulbs that are 4300k but that's still close. It does not get into the 6000k area and definitely not higher.
Old 08-26-04, 09:34 PM
rominl
exclusive matchup
rominl's Avatar
all factory hids (no matter what companies) are 4100k to 4300k. that's the only street legal color temperature for hid bulb here in the US
Old 08-29-04, 08:52 AM
BrickHead
BrickHead's Avatar
I am confused... I just ordered a Philips 5000K as a replacement for my 98 LS400 after reading this... Did I buy the wrong kind?
http://faq.auto.light.tripod.com/hl-hid-bulbs.htm
The hard facts on 5000K Philips:
Marketing name is currently "Plus". Production started up mid Sept 2002.
This will cover the demand for a bulb that will have the same colortemp as an OEM bulb on a 2-4 year old car, without losing any real performance. Typical use would be for replacing bulb on a high end car with more than 1000 hours of use, so that color is matched better than a new OEM bulb. Base will be labled "ECE". Expect bulbs to show up at dealers during summer 2003.
OEM Philips D2S is 3200lm bright (+/-450lm) and 4100K colortemp (0.380x 0.390y). (For comparison)
Philips 5000K D2S is 3100lm bright (+/-???lm) and 5000K colortemp.
Old 08-29-04, 09:14 AM
AA Concepts
AA Concepts's Avatar
5000Ks are good bulbs, lots of Lumination and a nice color band.
good buy
Old 08-29-04, 09:48 AM
BrickHead
BrickHead's Avatar
LCA575,
I am replacing only one of my low beam bulbs. Do you think it's going to have a different (brighter) color than the existing bulb? I was under the impression that a 4100k bulb would look more yellow next to the existing bulb. Thanks for your input.
Kevin
Old 08-29-04, 06:20 PM
AA Concepts
yes, the 5000K will be bluer than stock, I believe there is a HID color chart in the sticky in this forum. Refer to that to see the difference in color temp color.
Old 08-30-04, 12:09 AM
rominl
exclusive matchup
rominl's Avatar
Originally posted by BrickHead
LCA575,
Kevin
the color would be quite different. in fact, even if you get another 4100k replacement the color would be different, coz' the bulb color constantly changes over time
Old 08-30-04, 09:17 PM
BlkOnBlkGS
BlkOnBlkGS's Avatar
5000k will look blueish white like most OEM HID after about 100hours of burn in time.
Old 08-30-04, 10:21 PM
rominl
exclusive matchup
rominl's Avatar
it will look quite a bit whiter/bluer than the stock hid
Old 08-30-04, 10:46 PM
RayGS3
RayGS3's Avatar
For the 5000k, is the bulb tube clear glass or tinted blue?
Old 08-30-04, 11:27 PM
rominl
exclusive matchup
rominl's Avatar
better be clear, if it's blue, it's fake 5000k
Old 09-14-04, 10:04 AM
BrickHead
BrickHead's Avatar
Why would a new HID bulb change color from white to amber after it's installed? After 10 minutes it's as amber as a regular light bulb? A defective bulb? In addition, how can u tell if the bulb is 5000k or 4100k by looking at it or its package? I don't see that anywhere on the bulb or the box it came in.
Quick Reply: xenon hid headlamps
