Mounting the Ballast in The 400
Where did you guys mount your ballast for HIDS when you installed them on the drivers side. Passaenger side is so easy. Also do you guys who retrofitted what wires did you connect the wires from the ballast to. Straight to the factory harness just clip the factory connecter? or a custom harness?
Philly
Philly
I used manufacturer's brackets.
https://www.clublexus.com/forums/sho...hreadid=130489
They're still available...
Originally posted by Calvin L
right in front of the battery.
bless the invention of zipties
Radiator Shroud
Here is where I have mine.
Details can be found in this thread regarding SC ballast mounting locations:
https://www.clublexus.com/forums/sho...hreadid=124330
Re: Radiator Shroud
Re: Re: Radiator Shroud
Originally posted by BlkOnBlkGS
You dont have issues with any water getting in there during rain? Looks like a bad spot to mount.
