hid kit help
hid kit help
hey i just installed an hid kit, then 2 hours later after using them i got a check engine light. could this have been from the kit or is it just coincidence? the reason i think it might be from the kit is because it runs at 35 watts and the factory bulbs run at 55.
also it appears as if one bulb is way more white then the other. is this normal or is there a burn in time or something where they will even out?
thank you very much guys
vinh
vinh
