LED Replacement Bulbs
After all that time surviving in the SC section, it's finally been moved to the land of no return.
NYLex: If you're up to it, you can modify your headlights to fit Polarg M-6 pulbs which are pretty damn bright.
Have a read HERE.
Cheers,
~Alan
Have a read HERE.
Cheers,
~Alan
Have a read HERE.
Cheers,
~Alan
Have a read HERE.
Cheers,
~Alan
There is a clear "cap" over the bulb (on the inside of the headlight).
When you have the headlights open, take off that cap. It does abosolutely nothing, but if you try to put an M-6 without removing the cap, it won't fit.
Good luck.
Cheers,
~Alan
Good luck.
Cheers,
~Alan
Thank you much, if its that simple then I'll just fool around with it when I open them up and check it out. I'll buy the M6s beforehand, that whay I can have them in hand and do whatever it takes to make it fit
Good luck.
Cheers,
~Alan
Good luck.
Cheers,
~Alan
Yes. And Yes.
BlueCrabby
RX - 1st Gen (1999-2003)
02-06-14 09:29 PM
Chumacher
02-09-08 01:00 PM
