headlight beam pattern
Could anyone post what a stock sc's headlights cut off, pattern looks like against a wall.
trying to adjust mine and the levels on the lights are off.
thanks
thanks
thanks
thanks
I will post one when i get home, the cut off line isn't that bad actually. Its very sharp from 10-20ft away. When you get any further than that, it gets blurred and starts to spread out too much. I have a HID Conversion and it helps a little, but its not nearly as bright and as sharp (over a distance) as a stock HID or a retrofitted system.
I would really appreciate that, it woud be a huge help. 10 to 15ft distance for the stock projectors would be great!!!!
Thanks very much!
Lee
Thanks very much!
Lee
![](https://www.clublexus.com/gallery/uploads/21448/10ft.jpg)
This is from about a 10-12ft distance.
Hope this helps
This is a little better picture I took tonight. I also put a diagram of what the pattern should be adjusted to. This is what it should look like from about 30 ft. away
![](https://www.clublexus.com/gallery/data/500/21448bothlights-med.jpg)
shahir18
10-10-06 05:27 PM
