5300k vs. 6000k HID Bulbs
Old 01-03-05, 07:21 PM
gapxguy
gapxguy's Avatar
Default 5300k vs. 6000k HID Bulbs
I'm planning to upgrade my stock HID bulbs to something a little bit brighter with a tad of a purple tint. At the same time, I have yellow foglights and I'm afraid the purple-ness in the 6000k would look funny with yellow fogs. What do you guys recommend? Does anyone have pictures of 6000k with yellow fogs? The 5300k is just bright white correct? Stock is 4100k? Thanks guys.
Old 01-03-05, 08:32 PM
Neo
The One
Neo's Avatar
Actually, 6000k is not purple. It is white with a hint of blue. Sorry no yellow fogs but here is an old one of mine with 6000k in Halogen housings with clear fogs:
Old 01-03-05, 09:24 PM
gapxguy
gapxguy's Avatar
Neo, did you have factory HID before? If so was there a big difference between stock HID and 6000k? I would like to see 6000k compared to 4100k if anyone has pictures. That's a very nice shade btw Neo, I'm leaning towards the 6000k due to your picture.
Old 01-04-05, 12:27 AM
Neo
The One
Neo's Avatar
Nope. Halogens. This is a pic of the 6000k HID kit in halogen housings. It should "project" cleaner with HID housings but the color should be similar.
Old 01-04-05, 01:53 AM
rominl
exclusive matchup
rominl's Avatar
i have factory hid, bulbs changed to 6000k, and i have the factory fogs. i think they look awesome
Old 01-04-05, 02:32 PM
gapxguy
gapxguy's Avatar
Any pictures Rominl?
Old 01-04-05, 10:06 PM
rominl
exclusive matchup
rominl's Avatar
ummm i tried to take pics before, but first of all the color just doesn't show up nice on pics, plus it's very hard to capture evreything coz' it's so bright
i can try again, but the car is like 350 miles away, so gotta wait...
Old 01-05-05, 08:21 AM
MASH835
MASH835's Avatar
I read in this forum before that the 4100K bulbs becomes more blue after 100hours, are the 6000K bulbs also have the same change? will they become more blue/purple!
Old 01-05-05, 08:28 AM
NT2SHBBY
NT2SHBBY's Avatar
negative....actually REAL german 6000k bulbs (Phillips) ARE purple...I know I paid $400 for em almost 2 years ago.
they are the most colored HID capsule, without sacrificing too much lumen loss
btw, to the original poster, 5000k bulbs were phillips answer to ppl who burnt out 1 stock OEM 4300k bulb...after I think 1000 on time hours, the 4300k bulbs "shift" to 5000k in color
this way, the owner could buy one bulb, instead of two (so the colors would match)
Old 01-05-05, 09:45 AM
Neo
The One
Neo's Avatar
Well, both my bulbs and ballasts are Philips and the color is certainly not purple.
Old 01-05-05, 09:57 AM
gapxguy
gapxguy's Avatar
I got into a car accident and the driver side headlight is out. The bodyshop replaced the whole HID headlight assembly with a new ballast and bulb. So is this gonna match the other side color wise? My GS400 is a 98', so it's probably had quite a few hours used up.
Old 01-05-05, 10:22 AM
NT2SHBBY
NT2SHBBY's Avatar
no it won't....heirgo the 5000k series
your old side will be more blue
Old 01-05-05, 10:24 AM
NT2SHBBY
NT2SHBBY's Avatar
to be honest, I am not and never was a fan of HID retro kits, (especially after 2 died on me way back when)
real phillips 6000k Ultinon D2R/D2S capsules are purple with a hint of white/yellow
Old 01-05-05, 12:43 PM
rominl
exclusive matchup
rominl's Avatar
honestly, the whole thing about white/yellow/blue/purple, no one can say it for sure. from different angle, different background, different usage, you get different color anyway. philips is no doubt the pioneer in hid. they are that good. if you put the philips 6000k with the stock, you think it's white with a bit blue. if you put it together with osram 6000k, you think it has a bit purple (the osram is whiter). if you put it together with the 7500k, you think it's purple, if you put it together with 8000k or 10000k, you think it's blue. so nop, personally i will not say definitely it's purple, and i don't think anyone can PROVE that. i will just say it's whiter than 4300k, and it has a bit blue/purple in it. specially if the car is rolling, on certain angle you see purple. on most angle you see white/blue
and neo has real philips bulbs too, i am very sure and all 6000k bulbs, as long as they don't have the colored glass, they give out roughly the same amoutn of lumens anyway
all hid bulbs will have a burn in time, after the burn in time it will look a bit bluer and richer in color. over time it will just get bluer and bluer and one say it's gone
you should also ask for two new bulbs, coz' the two hid bulbs won't match each other at all. and getting 5000k is not the answer too, coz' over time they will just get bluer and bluer, you don't know if your headlights are now 5000k or 5400k, or 5800k...
Old 01-05-05, 01:24 PM
Neo
The One
Neo's Avatar
I am not quite sure what the two has do do with eachother. HID kits have pros and cons but Philips 6000k bulbs are 6000k bulbs. If you put D2S bulbs in projectors vs D2R bulbs in reflectors, then there is a color difference (mainly because of the projector lens). The bulbs on its own burns pretty white to me.
Quick Reply: 5300k vs. 6000k HID Bulbs
