Fitting HID bulb into H3 socket
I want to fit HID D2 base bulb into H3 socket, but because the H3 bulb is shorter than HID bulb it hits the fog light bulb shield. So I think I should do either :
- use washer as spacer between the bulb base and the socket
- remove the shield
What is better ? and if I am going to remove shield how it will affect the light pattern and output? Better or worst!!
And if anyone removed the shield, how to do it? I know there is a screw but don't know how to reach it (open the fog light assembly).
Any suggestions, Thanks.
- remove the shield
I noticed there are holes in the fog assembly where the front glass fits. I tried to pry open it but couldn't remove it, I think it is sealed. I will try to put it in the oven, but first i will see how much the fog assembly cost.. may be I'll get new set specially if going to retrofit a projector there!!
sockfocks
12
04-18-07 05:38 AM
