My SC LED Retrofits
Old 02-27-05, 03:17 AM
  #31
LasVegasGS
LasVegasGS's Avatar
Hey what kind of silicone did you use brand name & stuff I tryed this one type its worse then Hot glue sucks & comes apart easy
Also I went to home depot they didnt know what the hell clear dimpled diffuser where did you get it & what brand. Thank you
Old 02-28-05, 05:23 AM
  #32
CleanSC
CleanSC's Avatar
The silicone I used was for aquariums. Not sure of the brand, just get aquarium clear silicone and you're good.
The dimpled diffuser you will find in the lighting section. It's the sheets they use in office flourescent lighting to cover the fixtures. Comes in a 2'x4' section. There's different styles, pick the one you like best. If you're in an office right now, just look up.
Old 02-28-05, 11:28 AM
  #33
LasVegasGS
LasVegasGS's Avatar
So you put a dimpled diffuser inside the houseign in front of the LED's right?
Old 02-28-05, 12:00 PM
  #34
CleanSC
CleanSC's Avatar
Right.
Old 05-05-05, 04:34 AM
  #35
KoSC300
KoSC300's Avatar
Sweet ride CleanSC, and please do a write-up of this side marker, either of you. im interested in maybe trying it soon. Great work both of you.
Komain S.
Old 05-05-05, 05:44 AM
  #36
CleanSC
CleanSC's Avatar
Komain:
There really isn't any set instructions on how to do this as it's totally up to what you're after...
First, you start with making your own clear lights as described in this thread: https://www.clublexus.com/forums/sho...d.php?t=118213
After you master that, all you need to do is retro in your choice of led illumination. The easiest choice being the already-assembled 12-volt tractor trailer or boat trailer led marker lights. Seal it up watertight and that's it.
LasVegasGS did an awesome job in this thread with the pics and info as he did his.
Good luck, and if you have any specific questions, feel free to ask.
Old 05-05-05, 03:28 PM
  #37
got_trd
got_trd's Avatar
I think if you put the LEP strip from the sunroof to the top of the rear window it'd look better.
Old 05-06-05, 05:12 AM
  #38
CleanSC
CleanSC's Avatar
From OLT's thread here: https://www.clublexus.com/forums/sho...d.php?t=148882
Originally Posted by CleanSC
I had looked into the upper rear window as a location but that doesn't works as a) that entire area is curved, b) the flashback from the rear window lit up the entire cabin and c) the glare made looking out the rear window impossible.
Haha trust me I would have loved to put the light there. But when I attempted it, it was just not working.
Old 08-09-05, 08:47 PM
  #39
SprtDesign
SprtDesign's Avatar
I brought LED strips to mod to my taillights. They only had a positive and negative wire connnected to them. Simple I thought. I connected them to the postive and negative bulb wires and the fired up. Cool. Once I press on the brake pedal they cut off. what gives?
Old 08-10-05, 05:46 AM
  #40
CleanSC
CleanSC's Avatar
Obviously that's not right. Does the stock brake light work okay? If so, you have wired them incorrectly somehow. We'll need some more details to diagnose this...
Old 07-02-07, 08:15 PM
  #41
HTQCummins
HTQCummins's Avatar
how did you get the led strip to mount to the sunroof, and how did u get the bar that the LED's are in black?
Old 07-03-07, 04:54 AM
  #42
CleanSC
CleanSC's Avatar
Whew - reviving threads over 2 years in hibernation.
Your best bet for these types of things are eBay and poking around in junkyards. You'd be surprised what you can find wandering thru a junkyard.
Old 07-03-07, 06:53 AM
  #43
HTQCummins
HTQCummins's Avatar
i was actually directed here from a newer thread. your car is beautiful tho
Old 07-03-07, 07:03 AM
  #44
CleanSC
CleanSC's Avatar
Haha it wasn't a complaint at all.
Keep your eyes open and you'll find the stuff you need to get your retros done.
Old 07-03-07, 09:37 AM
  #45
memasterac
memasterac's Avatar
cleanSC, your LEDs are sick. Love it so much.
Quick Reply: My SC LED Retrofits
