Help on fixing headlight adjustments
Does anyone know how to fix or may have had the same problem with their lowbeam adjustment screws. I dunno if i warped the bolt but when i turn it i do not see any movement in the beam pattern of the headlight. I have a sc300, there is a leveler that tells you if it is centered or not. On the horizontal adjustment leveler it is all the way to the left, i need to move it to the right but no matter how many times i turn it, it stays in the same place. Has anyone had the same problem or know how to fix this?
randomwalk
07-15-11 07:35 AM
