unsatify with Xenon Depot HID
Originally Posted by mikal
this is what I think...
When you told him you got 2 bulbs in the first shipment, he probably thought you got 2 "sets"
So then the second shipment, he packed everything else besides the other set of bulbs because he probably thought you said you got "two".
Just call him up on his # listed.
I believe it's a one man operation. Friend called him a few times. Went straight to his cellphone or something because he said he wasnt in the office.
I got a set of the Xenon Depot 4300k Philips Kit.
When you first install them, they power up blue then change to white then change to yellowish.
You gotta wait till the HID bulbs burn in. Usually Takes a while. Did you install with relay? Steves kit should come with the relay harness to power up the Ballast. Also make sure that you grounded down the relay harness correctly.
My HID's are now pure white turning blue. (many hours of use)
please post pics of your HID color out put. How long did you have the kit?
Former Sponsor
Hello,
As per your posts:
gstuned,
1) The 4300k bulbs will emit a bright white output with a bluish/yellowish tinge depending on the angle you view the bulb from. The Philips 4300k bulbs will colour shift within approx 100 hours and they can reach colour temperatures of up to 4700k. It is normal for your lights to be slightly different in colour as your headlights are angled differently from the factory. The 4300k bulbs will start off very blue and as they warm up they will fade out into a bright white with a yellowish/bluish tinge. This is normal. If you like, I would double check to make sure that you are getting a good ground as sometimes if the bulb is slighly yellow it is a sign of a poor ground. It sounds like what you were looking for would be the 6000k bulbs.
2) I personally packaged the second shipment that included the 2 bulbs as I wanted to make sure that you were getting everything you were entitled to - this was not a standard shipment. We have sold our product to numerous people on this forum and would not jeapordize ruining the relationship and image we have on this forum (or in general) over 2 bulbs. Keep in mind that we even sent you the second shipment which included 4 ballasts, 2 wiring harnesses, and bulbs (we could have just as easily said we shipped the complete package out the first time). Furthermore, after conducting an intensive inventory it appears that the bulbs were shipped (did this just to double check).
Mikal,
We are not a one man operation nor is the phone ever forwarded to a cell phone. What I do tell some customers is that my email is forwarded to my blackberry so that I can offer quicker email responses.
Regards,
Steve
As per your posts:
gstuned,
Mikal,
Regards,
Steve
Former Vendor
I had an issue with my lights only going on after 5-6 minutes and Steve was very helpful in showing me diagrams to check my relay and my wiring since my kit didn't ship with an instruction manual.
It turned out that a wire in the plug from the kit that connected to my stock headlight plug was loose and jamming it back into the plug fixed the issue.
I was also frustrated with the color output but I figured I'd drive around with the lights on during the day to speed up the 100 hour burn in period. They look a little whiter now.
All in all, I'd say that Steve offered good support and his e-mails were prompt.
Thanks Steve.
Clifford
Thanks Steve.
Clifford
pootie
10-27-10 05:26 PM
