How to reset "check tail lights" icon?
I got a warning light that indicated a prob with my rear lights. I had to replace a bulb. How can I get the warning light to go out? Thanks in advance, Tom
The light will go off when the problem is fixed. If it is staying on it means that you did not fix the problem.
I would check that you used 192 bulbs and not 168's - that is the most common culprit when all lights are working but the tail light check is still on.
Jonny
Jonny
