My Gs headlight retro
#31
Well heres another update, almost done with the lights. As you can see I decided to go with quad projector set up, I thought to my self hey why buy the ls projectors when I can have 4 , 2 in the high beams are from an X5. I still need to align the cut of, so that the purple is coming from both projectors at the same time at the same angle. And there you see my headlight lense, turned out great and could be better if I took more time but I really want to get it done so yep all I need to do now is start the 2nd one
#33
Originally Posted by rominl
damn, 4 hid, that's something, good for show for sure
why the low beam color doesn't look as good as the high beam?
hey are those e46 projectors in the highbeam?
just curious why did u decide to put the rx330 projectors so far back?
#34
Its a different color b/c I havent aligned the cutof's, once I do both will give of the purple at the same time. And I put it that far back b/c I wanted to go for a more oem look, but I blew that with the 4 hids
#35
exclusive matchup
but i am curious, what made you decided to put hid on the high beam, for show off?
#37
Its an x5 projector for high beam and a rx330 for the low beam, there both modified, the x5 modded to give of more color and the 330 modded to give of more light. The reson I did this was because I had the 2 x5 projectors just layin around and because I wanted to simply put more light on the road and do something no one else tryed and so far its turning out real good, im working on the 2nd light now and im pretty much busy 24/7 with some school stuff and this. I got some more Hid gs headlights, that I can sell and I just started to play around with one Hid reflector I have and Im able to modify it to give of more light, actually there is way more light on the road w/o any glare so I can pretty much custom paint the headlight inner housing to anyones request and remove the orange turn signal's and modify them to give of more light. Cant wait to get both of my headlights done so I can turn darkness into daylight oh and ps: those are e-39 projectors
#38
haha good so you went and did the Bimmer High Beam projectors too i see? is it just for looks? or are you planning on driving w/ all 4 on at the same time?
great job on the lens.... I was skeptical about the final clarity but looks like you knocked it outta the park w/ that one!
#40
LoL I just decided to redo my low beam and put the projector deeper and im going to use a shroud on it , here we go again. Oh and ps: yes im going to run all 4 of them on when im driving
Oconee1985
SC- 1st Gen (1992-2000)
06-22-15 02:16 PM
keyur246
10-30-13 10:49 AM
