need help on installing hid's !!!!!
#33
For our HID Install, RayGS3 and I both used the female connectors below (bought from Radio Shack) and attached them to the OEM HID connector also pictured below. I cut off the stock 9006 connector and attached the female connector. There is a little piece of plastic inbetween the positive and negative prongs on the OEM HID connector to keep them from touching. Then we wrapped the connection up with electrical tape. I am still using the 15 amp fuse that was used for my halogens and have not had any problems.
![](http://www.radioshack.com/images/ProductCatalog/ProductImage/64/64-3134.jpg)
![](https://www.clublexus.com/forums/attachments/lighting/66683-need-help-on-installing-hid-s-picture-305.jpg)
#34
Please keep a fire extinguiser in your car. Thanks.
#41
mikal ...man i cant thank you enough iam referring to this thread again cause i have a bad ignitor in my stock ballast and i have to get some more of those connectors ad resolder them to the new ballast so thanks !! ANYBODY OUT THERE I NEED A OEM BALLAST PLEASE PM ME IF YOU HAVE 1 i got pulled over tonight cause of the headlight out !!
#42
hmm why do you have to run another whole harness from xenondepot? can't you just get a jumper harness from a halogen 9006 plug to a hid d2r plug? i just bought some oem hid headlights and its on its way and that is what i was planning on doing?
#44
i was wondering if someone can help me find a part number. i need the plug that plugs into this HID ballast plug. it is the female plug that i need. with a couple inches of wire on the end. reason is because i am trying to make a jumper or conversion harness from a 9006 plug to a oem hid ballast plug.
![](http://img.photobucket.com/albums/v63/chynkster/ballastoemplug2.jpg)
#45
Lexus does not sell the plugs itself, you would need to special order the whole oem Headlight harness from them if you want to have a direct plug in. Which would probabaly cost $800+
(i tired to buy an hid plug for a 350z, they can only sell me the whole harness)
