Hid
Okay, last night as I was drive, my driver side HID changed its color to purple, at first, I thought it's kind of cool, however, I think my HID is about to burn out, I thought they suppose to last forever. Anyway, has anyone had some thing happen to them?
If it turned purple that means its burning at a higher kelvin, check the light output at night compare the 2, I'm sure the one that turned purple is putting out alot less light. Like corky said they are really inexpansive if you replace with oem bulbs, at most they will cost about as much as a pair of halogen silverstar light bulbs.
The One
Originally Posted by DXGS400
Thanks for all the replies. Yes, the purple one is lot more dimmer than the other one. I am going to purchase a pair on ebay, I don't know which one I should go for, 45K, 5K or 8K, what do you guys think?
The OEM ones are in the 4100K - 4300K range. 5000K and 6000K would give you a little bit less light but better blueish color.
I would not go any higher as you start to lose much more light and the color is purplish, unless this is what you want to do.
Originally Posted by corkycal
Ebay has brand new philips D2R bulbs for about $80.00 a pair. If you're talking about retrofitted D2R or D2S bulbs, I don't know the pricing. Regardless, very inexpensive for bulbs.
4double0
07-27-04 10:06 AM
