Lexus Sc300/400 Retrofit Kit?
i was browsing the HIDplanet forums and came across the HID projector kit. this isnt that ebay crap..
check this out
http://www.hidplanet.com/package.html
the first kit on top
i was wondering if i bought this.. all i would need is that adapter plate? correct?
i searched on this topic already but couldnt find anythign on the hidplanet HID retrofit kit...
thanks
check this out
thanks
All you would possibly need is a wire harness and that's it. You'd be good to go with this retrofited into your vechicle. Whic Lex do you drive? You may need some sort of shroud to cover the projector in your headlight depending on the car its going into
check this out
thanks
check this out
thanks
If you guys want to retro your sc's you would need 3 inch projectors to make it look oem. I have a valeo d1s kit that I can post pictures of and the price is also less then on that site.
okay here is the pic of what I have.
[img]https://www.clublexus.com/gallery/data/500/medium/DSC00219.JPG[img]
the projector is roughly the size of the oem projector thus you wont have the problem of having a smaller diameter projector lense inside looking way of normal. pm if anyone is interested.
i emailed the sales repp and they sent me this
http://www.hidplanet.com/bosch.html
http://www.hidplanet.com/valeo.html
the dimensions os the lens are not 3 inches they are 2 1/4 and 2 5/8 soooo. . . IDK
Those are valeo projectors that came out of a jag, audis use valeo's in there a4's. Valeo projectors are realllly easy to mod for more color at the cut of but the great thing about these is there lens is 3 inches wide which would sit pretty flush in any halogen housing. And yes they come with bulbs and ballast.
Here's an example of what to expect.
https://www.clublexus.com/forums/sho...light=retrofit
Only I suggest painting the housing trim a flat silver or black like my ES300 retrofit
https://www.clublexus.com/forums/sho...ES300+retrofit
to avoid the glare and hot spots above his cuttoff line so it comes out cleaner output wise
As for the wire harness, I can help you with that.
