Need opinion on LED bulbs
Looking for an opinion from you guys on the led bulbs that are all over ebay. I want to swap all the stock bulbs on my 01 gs430 with these led lights, but I do not know if I should because I heard they are actually a lot dimmer than stock bulbs.
Led bulbs are great in some areas and not in others. I changed my city lights on my IS to leds and I'm very happy with them. A while back I ordered Leds for the turn signals and brake lights. ended up that the turn signals were not bright enough and I would to have bough this other adapter to make them stop blinking so fast. I didn't try the break lights cause I didn't think they would be bright enough. Your only hope is to find some that are bright enough and shine backwards to the reflectors in the light houseing so that they will light up the whole brake light or turn signal whatever your trying to do. If not your going to get a consintrated red light thats not going to be very bright. Those are my experences with leds but maybe someone else has another solution. Hope this helps.
Chase.
Chase.
Chase.
Chase.
Originally Posted by Och
I see, this is exactly what I was afraid of. I guess I wont be doing this since the primary reason I was even considering it is in order to make lights brighter, not dimmer.
Chase
