Blown Headlight!!!
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
[SIZE=6]I have a 92' SC400 and the driver's side headlight just stop working........Is this a common problem and where do I start troubleshooting? Thanks![/SIZE]
check the fuse, if the fuse is blown that means you have an open circuit. Somewhere in the wires leading to the bulb the positive and negative are touching or the positive is touching the chassy.
