Retrofit sc400
Retrofit sc400
its coming real soon....
Thanks to mike...great to have friends in high places lmaoo
heres whats going on so far......
im gonna be using the rx 330 sheilds from mdx cant wait to see the out come....
I can't wait to see the end results! Jermaine knock it out!
ok ok ok
ok here we go back on track( what up mike!!) ok im not gonna go with the rx330 nomore very bur cut off so im going with the mdx's....ok here the new run down mdx projectors 3 washer on each projector mikes sc300/400 retrofit brackets and my brain....ok heres what mike gave me
Originally Posted by datsetup
ok here we go back on track( what up mike!!) ok im not gonna go with the rx330 nomore very bur cut off ....
I have RX330 HID projectors, cutoff is perfect with D2 bulb. You have to use metal shields between mirror and lens, your picture doesnt show it , do you have it?
Anyway RX projector is to big to fit SC housings w/o extensive modification. I droped it cause IMO would compromise reliability of the headlight.
Now, on the picture I see polycarbonate bracket you made on the back of the MDX mirror, it look like it follows the contur of SC bracket, I wonder what you going to do with all the material sticking above bracket`s upper edge, how you are going to fit it in SC housing?
oo
yess sir..... im not going with the rx330 cus i dont have the shields, but the light that come out of them is badd(meaning nice), very wide beam but besides that the cut off on the mdx is very clean and color on top of the cut off... im tryna to get them in to the sc housing but its been raining over here but will try to have them in asap...cant wait
I see you guys got quite HID brainstorm in this forum, glad I found it, by accident though (okami dumped my SC HID thread down here...)
Now, get SC headlight housing and try to stick thet projector you have in it. This is where I stopped with my RX330 projectors. SC housing is very narrow....
Maybe you guys can come out with something here....
0000
well the sc housing where the projector sticks out i think that hole is more then 3" wide the mdx's is a lil over 2 1/2" wide the rx's are 3" wide so the rx's would be a tight fit but a lil sanding would fix that
I can`t confirm your numbers RX are almost 4inches, 98mm exctly.
SC projector lil over 3inches, 78mm exactly.
That is 20mm difference, almost inch, no lil sanding here...
ok ok heres my rx's 330
OK I see where we have missunderstanding....
Lets try different way, horizontal messurments you are making are not the problem, there is enough room.
Vertical messurment, taken where projector fits housing, where parabolic mirror mets lens bracket. That what I`m talking `bout...
