96 ES300's bulbs
96 ES300's bulbs
Hi, all ES300 Fans. Need your big help.
I really need your kind advices to teach me replacing the front light bulbs and the frog light bulbs as shown the attached photo ( I have circled the light bulbs which I want to replace). The problem I encountered is that I can't find the right place to dismantle them. What's the technique to take them out? can you guys teach me step by step? Thx lotz!
replace lights
follow the picture below:
remove these plugs
by pushing the middle pin down 1mm...very slight you will feel it click
once removed. disconnect the high and low beam bulbs. You will see 2 bolts. undo those and slowly remove the headlight. dont move to far and you can see where you can unscrew the blinker bulb.
for the foglights. there are 2 bolts that hold the entire assembly to the car. the rest you will see how to remove the bulb. DO NOT touch the new bulb with your fingers.
if you want to clear the corners of your headlights follow this link.
clear corners
to look like this:
remove these plugs
clear corners
to look like this:
