Changing the vertical angle of SC300 Headlights
One of my headlights is higher than the other. Looked in the manual, but it only says to take it to the dealer.
Does anyone know how to lower the angle of the headlight on SC300?
Thanks.
Thanks.
you should see a long metal rod comming out the back of the lamp assembly near where you change the turn signal blub. the one lower down to the right (facing back of car) on the assembly is for the horizontal adjustment. the bubble level you see on the assembly is to help position vertical adjustmet.
hope this helps.
hope this helps.
