i used a butter knife with tape to protect the plastic trim. i inserted the blade on the side closest to the sunroof. it's kind of a pain to get out & i thought i was going to break something, but the cover is pretty durable. if you pry the cover down a little, then move the blade over a bit and pull the cover down a little more, it should pop out relatively easily.
