people who converted their cornering lights to fogs
For the people who converted their cornering lights to Fog Lights on their 92-94 SC, are you able to have it so you can choose when you want both headights and corerning lights on? What if at times, you just want the Cornering Lights ON and the Headlights OFF and Vice Versa? How is that done?
I am actually doing this mod later this morning (after work), and if i understand the procedure, the corner lights will be on depending on what you wire from. So if you run from the + on the parking lights, they will come on with the parking lights and so on. In turn, they would obviously stay on when you turn the headlights on. Or if you run from the + on the headlights, they would only come on with the headlights on. This is how understand the DIY anyway.
....I'm not inclined enough electrically to know how, but there is probably a way to install a completely seperate switch to turn the cornering lights on and off seperate from anything else. After rereading your post, this may be what you asking?? If so, my bad
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Yeah, I know at times I'd like to have both Headlights On and Cornering Lights On, but I was just wondering if at times I could have JUST the cornering lights on while my headlights off. and sometimes have just my headlights on with my cornering lights off.
