IS250 - Will my high beams still work if I replace my low beam bulbs with HIDs?
I'm going to buy HIDs for my low beams, which is H11 correct? My question is if I get the bulbs/ballasts for my low beams, will my high beams still work?
BahHumBug
the only time high beam will be lost is when you have a dual filament bulb (9003 or 9007) when the low beam bulb has 2 filaments, one for low beam, and another which is a high beam and is on at the same time the high beam bulb is on. you wont have this problem since u use H11 bulbs i believe, which are single filament.
Returd
Performance & Maintenance
11-22-18 05:47 PM
