how to remove bulb in shifter gate
08-06-06, 05:43 PM
I want to change the wedge bulb in the shifter gate to LED. How do I get access to the bulb?
08-06-06, 06:14 PM
BahHumBug
id like to know this too
08-06-06, 06:19 PM
3UZ-FEEEE
That is actually very easy.
Well, remove the wooden shifter, then use a flat head (put some tape over the edges) remove teh wood. Open the center console, and use that edge, adn carefully pull the wood through. Then pull on the plastic to remove the shifter unit, and then twist the bulb out of place.
I know on the LS, that not a single bolt, or a screw is involved.
08-06-06, 11:09 PM
BahHumBug
Hey Grand, do you by any chance know what size/kind of bulb(s) are used? i wanna do a color swap.
08-07-06, 02:13 PM
3UZ-FEEEE
No, im sorry I dont. But I do know it has a green cover on it. I've actually took off the shifer gate a few times to buff it out, including the wood that surounds.
It will take you about 5 times to reach it. Just becareful when pulling off the wood. Becareful not to scrach your Headunit when putting it back in.
08-07-06, 06:32 PM
This is for a GS400 guys.
08-07-06, 06:57 PM
BahHumBug
Quote:
yea, but the GS and LS shared the same tranny and same style of shifter plates (for the GS400) so it should apply to my LS's
08-08-06, 07:27 AM
Its the same process and its a 74 bulb.
08-08-06, 08:36 AM
BahHumBug
Quote:
just 1 bulb?
08-08-06, 10:26 PM
Quote:
Originally Posted by PureDrifter
just 1 bulb?
yes 1 very small bulb and it has a green slip cover over it.
08-10-06, 02:54 AM
dubsonlexus
did you swap it out yet ?? any pics ??
08-11-06, 01:42 PM
3UZ-FEEEE
Quote:
yup, same for the LS.
08-13-06, 11:27 PM
BahHumBug
lexusondubs
not yet, im looking through the diagrams for the shifter and the way the lighting works to see whether or not i wanna use an LED or just a blue bulb.
08-16-06, 01:52 AM
Master Thread Closer!!
Yes...its #74....simple to replace....i remember see the bulb when I swapped out my burlwood to blackwood (non-stick on).
Pete
dsandife
01-04-24 06:36 AM
ReynoldG
04-29-18 10:55 AM
badams1897
09-14-13 05:19 AM
brit_lex
Lighting
11-25-06 03:16 PM
NYBlkLex
05-12-03 06:11 PM
