HID 6k light output problem
Old 08-16-06, 09:51 PM
Agent$mith
Agent$mith's Avatar
Default HID 6k light output problem
I had my HID for about 8 months now. Both came out blueish white at the beginning. When I turn it on now, I see both turning blue in the mirror, but then the passenger side starts to turn halogen white color as the driver side turns blueish white. What's up with my HID? I see the light on the passenger side flickering and stuff.
Can someone help me? Do I need a new kit?
Johnny
Old 08-16-06, 10:14 PM
AmCo
AmCo's Avatar
What kinda kit did you buy? A taiwanese knockoff?
Old 08-16-06, 10:25 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
sounds like a ballast issue.
probably a cheap ballast and bulb, shoulda gone with a big name like Phillips (xenondepot) or Mtec
Old 08-16-06, 10:33 PM
Agent$mith
Agent$mith's Avatar
Hmmm. I got it off ebay after another fellow clublexus member got it and was happy with it for 300. I know I should have put some extra cash and get it from xenondepot. Do you think it could be a connection problem or something loose? I was gonna swap the driver side to the passenger side to see what would happen to the output this weekend.
Old 08-17-06, 09:29 PM
dainese954
dainese954's Avatar
hope mine don't do that
Old 08-20-06, 06:13 PM
Agent$mith
Agent$mith's Avatar
I swapped the blueish bulb to the passenger side and it turned out to be the bulbs. I guess whoever sold it to me sold me a used bulb. I only had the kit for 6 months.
Does anyone know if I can buy some phillips 6k bulbs from xenondepot.com and change it with my kit? How would I connect it to my kit which is a different ballast?
Johnny
Old 08-23-06, 09:08 AM
SOHKis
SOHKis's Avatar
Johnny
Depending on what ballasts you have, you may be able to replace them with xenondepot bulbs, check here to see if the connections look at all similar:
http://www.xenondepot.com/category.php?category_id=6
more than likely they'll be under the XenonDepot Components, or the Xtreme HID Components. Depends on your connection between the bulb and the ballast.
IS2FIFTY
Lighting
04-08-12 08:00 PM
cenwesi
05-20-09 12:39 AM
rsx2crazy
Lighting
06-03-08 11:13 PM
carlos
Lighting
03-11-06 07:24 AM
96sc3
Lighting
12-06-04 12:04 AM
Quick Reply: HID 6k light output problem
