Strobing Turn Signal
My right turn signal in my 95 es300 is lighting up at least 2x faster than normal and i have checked that ALL the bulbs are still working. -Headache from that stupid clicking- The day before, i had just changed my ignition bulb to led..could this be a problem?
same thing happened to my 91 LS 400 ..i just changed my turn signals to clear one so it might be because of this. But only one side is faster than usual
I believe that happens because the bulb is about to die or what not. Like the sytem detects low bulb wattage and starts rapid flashing the bulb to tell you to replace it. I believe the same thing happens if you try to put in those special 12V LED bulbs (because they run on low wattage). Could be wrong though.
I'm always annoyed by those fast flashing signals.
Everything in Moderation
i12play
10-28-06 07:26 PM
