bad bulb or bad ballast?
Keeper of the light
turn it on, it warms up purple/red and stays on for 2 minutes then cuts off.
cut it back on a few minutes later... warms up red/purple, then 2 minutes later cuts off.
I gotta go find a bulb seller on ebay I think.
Keeper of the light
I'm gonna ****** these if it's the bulb as i suspect.
http://cm.ebay.com/cm/ck/1065-29392-...m=260026634940
exclusive matchup
i think it's bulb. easiest way is to swap bulb from the other side and see if it works. if so, then it's bulb, otherwise it's ballasts. keep in mind NEVER fire it unless bulbs are on both sides. fire it up with a socket empty, very bad idea.
(though i know you already went ahead with some new bulbs )
TXES350
ES - 5th Gen (2007-2012)
03-12-11 07:46 PM
