Q45 Retrofit completed. Pix Inside!
Old 10-19-06, 10:15 PM
JeffTsai
JeffTsai's Avatar
Default Q45 Retrofit completed. Pix Inside!
I just finished DallasGS4's retrofit. Took me quite a while to complete all the work, I just want to show you all the finished product
The camera flash reveals a ton of scratches from polishing, but they aren't visible to the naked eye. The outer lenses are very smooth and all the scratches and rock chips have been removed. And no, the Q45 projector is not touching the housing, it's just the camera angle. Note that the housing is paint matched to Diamond White
I'll get some beam shots posted when I install these on his car tomorrow.
Now on with the pix, enjoy!
JeffTsai is offline
Old 10-19-06, 10:18 PM
svt5150
svt5150's Avatar
Nice
So do you do this mod now or were these some of yours?
svt5150 is offline
Old 10-20-06, 12:09 AM
biggie
biggie's Avatar
Default Sweet
Very nice...can't wait to see them on the car.
biggie is offline
Old 10-20-06, 01:17 AM
Lexbox
Lexbox's Avatar
Finally someone put white on the inside so I can see how it looks! Cant wait to see the finished look.
Lexbox is offline
Old 10-20-06, 01:44 AM
Neo
The One
Neo's Avatar
Nice clean job. Did you use Soaristo's bracket design or did you do something else?
Neo is offline
Old 10-20-06, 02:05 AM
JeffTsai
JeffTsai's Avatar
Originally Posted by svt5150
Nice
It's a retrofit for a customer. This was actually only half a retrofit...meaning I redid/rebuilt the retrofit. The previous retro job was absolutely horrible. Paint/glue and scratches all over the place. Everything was horribly mis-aligned...etc.
The actual projector and several of the brackets were damaged by the previous "retrofitter"....I don't even think I can call him that lol. I pretty much had to re-align everything and glue it all together. Yes I know glue is not the best way to do this, but pretty much all the brackets on the projector were broken. I used a thermally stable glue to keep everything secured back in place.
Heh, yeah thats what I recommended when doing the retrofit. It's a different look, but it's unique. Nobody has ever paint-matched the housing to the car color so I guess theres a first time for everything
It turned out looking pretty nice so I guess this project was a success
JeffTsai is offline
Old 10-20-06, 07:27 AM
AJ
AJ's Avatar
We need night pics with high beams on , and car pics
AJ is offline
Old 10-20-06, 07:45 AM
mikevanle
mikevanle's Avatar
I think a black graphite housing would have looked nice. Painting to match the color of the car is a little too C6ish for me, which I don't like.
mikevanle is offline
Old 10-20-06, 08:16 AM
ACleanSC4
ACleanSC4's Avatar
I would have liked it a bit more if you left the ring around the Q45 projector in its original finish. Would have set it off a bit more. The paint looks quality on the housing, see lots of pearl in there...
ACleanSC4 is offline
Old 10-20-06, 08:40 AM
nadir
nadir's Avatar
freakin WOW
awesome job man they look extremely clean~!
nadir is offline
Old 10-20-06, 08:51 AM
R.U. IN AW?
R.U. IN AW?'s Avatar
Default Jaws Dropped.....
Jeff,
Damn that looks freacking amazing......care to do one for me? Really nice job.....
-Joe
R.U. IN AW? is offline
Old 10-20-06, 10:30 AM
Flufferiou
Flufferiou's Avatar
Awesome Job Man!
Would you mind doing one for me? You got PM!
Flufferiou is offline
Old 10-20-06, 10:31 AM
markgs4
markgs4's Avatar
Amazing work!!! Just looking at the end project, and the detail of it all...I cant imagine how much time and patience went it to it, but it was definitely worth it!!!!
markgs4 is offline
Old 10-20-06, 11:16 AM
JeffTsai
JeffTsai's Avatar
nadir
Well, the paint on the housing was actually done by a body shop. It cost around $75 to do the paint, but it's color matched to the car with the same 3 stage paint.
mikevanle
Well I recommended this because nobody has ever done this before. The buyer agreed with me on this, and it's really not too hard to pull out the outer housing to repaint later on.
ACleanSC4
The ring was messed up by the previous retrofitter. There was glue and corrosion all over the ring. I would of left it as is, but it would of looked horrible. Otherwise I agree that the original finish would of looked nicer.
RU-INAW, Flufferiou
As for whoever wants me to do these, yeah I can do it but it usually takes me a little while to complete. I'm juggling school time around with retrofit time . Usually my return time is going to be around 2-3 weeks.
markgs4
This is what I consider a "true retrofit". Some of the hack jobs I see really **** me off. They ruin the reputation of the real retrofitters, and also mess up peoples thoughts of what a good retro is supposed to look like. Not to mention they rip the buyer off several hundred or dollars. I might charge at a higher rate, and take longer to finish....but the end product and quality will explain why.
JeffTsai is offline
Old 10-20-06, 11:57 AM
LS400.1
LS400.1's Avatar
This is a mod I would love to do to my LS400.
LS400.1 is offline
Quick Reply: Q45 Retrofit completed. Pix Inside!
