Sc300 HID'ers!!
Sc300 HID'ers!!
...i just purchased a set of Mcullough HID's kit...I took apart my headlights, but i found no room to fit in my Ballasts...Can anyone help out, maybe pics would help of where to mount the Ballasts...It's a real tight fit in their!
Sorry...let me rephrase that, I removed my headlights.
I DO NOT want to put the ballast In the headlights. I'm just trying to find a place behind the headlights to mount the ballast.
Where did everyone else mount them?
if you got the xenondepot kit, they included brackets for you to mount it to a flat surface. me i mounted it on the flat portion near the headlight (battery relocated to trunk and open air filter so i can put them there). if i didn't have the batter relocated or open air filter, i would have probably put them on the side of them on the inner fender. here's a pic of the bracket xenondepot includes with their ballasts, also note that the slim ballasts help a lot too.
the brackets here are near the relay shown in the pic.
if you have the big ballast, i suggest maybe just doubleside tape to the passenger side of the airbox and driver side of the battery, be a tight fit but i think those are best spots.
unfortunately i didnt purchase the Xenon kit. I ended up buying the McCullough kit. Did the install. Thanks for the info everyone!
BEFORE:
AFTER:
I love it!
BEFORE:
AFTER:
I love it!
kind of a noob question here, but the SC's come stock with projector's right so there is no need to retrofit one's if you dont need to because a friend of mine with an LS insists that I would have to in order to go to HID headlights
hey guys, i suggest you do a search on retrofits on this forum
for people who have retrofits. im one of them
basically cheap way to get HID, just throw them on,
the correct way: do a retrofit.
why? because you could blind people with oem halogen and hid bulbs, they do not channel the light correctly.
also, check out hidplanet.com
i know that the few oem halogen projectors that are decent for HID bulbs are the ones that come on the MDX by Acura
Many projectors, even though equipt with Haligens from the factory, will product a great cutoff.
The projectors in my Jaguar are the SAME projectors they use in the Xenon equipment car (Valeo). I did the conversion my cutoff is identical to the Xenon equipt car.
My SC has the 97+ headlights and the cutoff is VERY clear and sharp.
