GS fog lights?
Former Vendor
i thought about this too and was experimenting with my HID fogs and HID headlights.
since i have aftermarket kits for both top and bottom - and if you do too - all you have to do is switch the "turn on" plugs to the ballasts...
so plug the headlight plug into your fog ballasts and your fog ballasts into your headlight ballasts... and then you can turn on your fogs like you turn on your headlights and then turn on your headlights like you do your fogs.
this only works if you have aftermarket HID conversion kits. if you don't - go check out bananags's site. He has a diagram on how to wire it all up.
FlamBDMV
06-28-10 07:59 AM
JohnM
SC- 1st Gen (1992-2000)
08-09-02 05:29 AM
