GS Non-HID to HID Conversion
I am interested in converting my non-HID equipped GS400 to HIDs. Here is my thought process: purchase a set of brand new Green tint headlamp assemblies and then purchase a HID kit from XenonDepot through the Group Buy thread. Would this be the correct way to go about things? I want to make sure that the light pattern is similar or better than the factory HID light pattern. Does anyone have recommendations on a better/similar priced way to do the converson? Any suggestions or tips are appreciated. Would my thinking work?
You should be able to find a wealth of info here in the lighting section on this project by using the search engine!
The One
2. Get the green tint only if you want green. There were OEM hids with different color housings.
3. If you stay with the OEM housings, the light pattern will be what it is. It won't better or worse than the OEM HIDs.
That is what I'm planning. OEM housings ballast\4300K bulbs\wiring adapter. I don't need the autoleveling computer connected (would cost too much to install)..Good luck and keep us posted...
1. Is cost a factor? If not, why not just get the OEM ballast and some D2R bulbs in the color temp you want. These will hook up with a few splices. The OEM ballast will mount below the housings, as designed.
3. If you stay with the OEM housings, the light pattern will be what it is. It won't better or worse than the OEM HIDs.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
i am going to be doing this conversion over the weekend. COMPLETE oem hid headlights, bulbs, and ballasts. all i need to convert is the factory hid plug off the headlight and splice in 9006 male plugs (which i bought from suvlights.com) and it should plug right up and work. a few on here is saying you need relays but a lot of people that have did the conversion on here says you don't need to either.
