what shall i do with my inner headlights ?
hi dudes
i need your advice on my 98 gs 400 halogen inner headlights . since my outer headlights are hid lights do you advice me to do the same for my inner ? or shall i just change the bulb into white or bluish one ? or what to do for a better looking>>>
thank you
thank you
hi
tcheung87
yes that is exactly what i ment...
cliffud
i will check the guide and the site...thanx man
still open for ideas and suggestions for the high beam and fog lights...
tcheung87
cliffud
just to be clear as well, if it's the high beam (the center bulb in the high beam housing), then you can get any super white and i think they will work ok
but if you are talking about the small bulb towards the bottom of the high beam housing, then it's a different story. i have the polarg m4
ok guys here is the outline :
for fog lights: 9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
for low beam headlight : polarg m4
for high beam headlight : 9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
so what do you think guys any suggestions or ideas, shall i go with these changes ?
-tc
I "borrowed" Cliff's car for this one, thanks man!
The BLUE arrow points to the High Beam reflector housing, utlizes a 9005 halogen.
The RED arrow points to the Parking Light wedge bulb inside the High Beam reflector housing, utlizes a 194/168 bulb, Polarg M4 would be ideal here.
The GREEN arrow points to the Low Beam reflector housing, where you stated you had HID.
The ORANGE arrow points to the Fog Lamps, they utilize 9006 halogen but can be converted to HID easily.
Hope this helps if you have any other questions please ask.
hey guys,
im looking to buy an hid conversion kit for my gs 400 to replace my Parking Light wedge bulb inside the High Beam reflector housing what do you think of bosch hid conversion kit and do you suggest the 6000k or 8000k ??
i found it on ebay for US $139.99.
thank you
thank you
after searching around i think i cant convert it to hid... if this is true then my next question will be :
is it possible to replace my low beam factory hid with a new hid kit and transfer the factory kit to my high beam with changing the bulbs of course....??
can it be done and is it easy....??
