high beam bulb replacement is350
i have 7000k nokya's in for my high beams, but when you look at the headlights, you can see the blue coming from the bulb. i use my hids almost all the time so i don't really use the high beams/drls but i wanted to put in a different bulb to get rid of the blue. i was thinking of the piaa tera led bulb...
http://www.amazon.com/exec/obidos/AS...o-20/ref=nosim
but i just wanted to make sure it won't mess anything up with the drls or high beams or anything.
p.s. i know it says $89 but i won't be spending that much... just curious if this bulb or anything like it will work fine.
