H.I.D. troubles
H.I.D. troubles
has N-E-one done a retro-fit (projectors, bulbs, ballast) and have trouble with it my headlights dont always come on and when they do they dont come on at the same time. i spend 20 min every morning fooling with this. could the ballast be bad? makes a predator sound when turning on . if this is in the wrong place, sorry!
Also, make sure you have a wire harness. It may not always effect your car but it might. In my case I've never used a wire harness. On my other car, a 1999 ES300, sometimes one of the bulbs wouldn't come on. On my current car, it only happened to me twice in over a year.
You might want to look into getting a wiring harness, as mentioned before, for your set-up. You will be providing your ballast a constant power rather than relying on your stock harness to provide the start up juice to your ballast.
yeah the polarity could be the problem... also what fuse # are u using...and does both lights comes on when your car is running?
sorry coundnt find this post. yes they come on while running but most of the time its just one. some times none? no this isnt one of those plug n play kits. i brought these from some guy on craigslist . i think there fine. i have a mercedes set up. ok ..when you say wire harness are you talking about a specific part? this is driving me nuts. i will check fuse tomorrow. im sorry how do i switch polarity?
A wire harness is a separate set of wires aside from the ones you use to plug your HID kit to. It uses beefed up wires and has it's own fuses and relay and draws power directly from the battery instead of from you electrical system to make sure you get the right power.
N-E one retofit sc?
ok i just spend an hour and a half reading up on this. and i still dont know exactly what to do. but what i gathered is. i definetly need a wire harness to protect my stock wiring (thanx Kanedl25). threw the links on the interlexuall site they say you can buy or make your own. So is there N-E one here that has an sc that has done this with good results?
GSteg
General Classifieds
07-05-07 09:45 PM
