GS400 HID turning purple? 3 questions
Old 01-31-07, 02:10 PM
David1969
David1969's Avatar
Default GS400 HID turning purple? 3 questions
I noticed one of my headlights changing colors the other night while i was driving. I was pulling into my driveway and noticed the color reflecting off of my garage wall. The passenger side light was a purple-ish color while my other HID was the white-ish blue it normally is.
When HID's are about to go out, do they turn purple?
If it needs to be replaced, recommendations on most inexpensive place to buy these bulbs?
Is there a DIY to replace these lights without having to take it to dealer?
TIA
Old 01-31-07, 02:27 PM
chrispy
chrispy's Avatar
HID bulbs will grow dimmer and color shift as the get older (used). Usually if you have a matching pair, they will shift at the same time. If a bulb goes out, it's better to get a new matching pair of D2R bulbs to make sure they match during their life. You can change them just like how you would change a regular halogen bulb.
Old 01-31-07, 03:25 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
check out the sylvania silverstar website that's in the sticky above.. They carry all oem size bulbs for our GS's. Buying the stock oem D2R bulbs are inexpensive than the aftermarket ones.. GL keep us posted.
Old 01-31-07, 05:17 PM
David1969
David1969's Avatar
Thanks guys. What are the stock headlight beam color(i.e. 4.5k, 6k, 10k)? I'd like to keep the OEM look.
Old 01-31-07, 05:48 PM
tmf2004
tmf2004's Avatar
I beleive there 4300k...
Old 01-31-07, 09:17 PM
rominl
exclusive matchup
rominl's Avatar
yes oem is 4300k. please make sure you get good brand ones, like philips. don't get cheap ones, you will regret
i have posted instructions before on how to change them
https://www.clublexus.com/forums/sho....php?p=1582870
Old 01-31-07, 09:18 PM
David1969
David1969's Avatar
Thank you, sir. Just bought me a replacement Philips bulb.
http://cgi.ebay.com/ebaymotors/ws/eB...1082136&rd=1,1
Old 02-03-07, 12:17 AM
TRD_Power
TRD_Power's Avatar
I'm having the same problem as you. I bought 2 brand new Philips bulbs and one is very purple while the other is white still. So I dunno about them always aging the same. I'm just gonna leave it for now and see if the other shifts. Didn't know only one year of use would cause them to change so much
Old 02-03-07, 09:33 AM
David1969
David1969's Avatar
You bought both bulbs 1 year ago or did you recently buy one/both and one of them is purple from the time you installed it?
Old 02-03-07, 09:50 AM
TRD_Power
TRD_Power's Avatar
bought them both at the same time and they matched perfectly fine up until a few weeks ago.
PeteGS300
03-12-12 07:12 PM
laumouth
Lighting
13
02-14-08 01:26 PM
YoshRX300
RX - 1st Gen (1999-2003)
04-30-07 03:39 PM
garbage85
Lighting
02-10-06 05:59 AM
mjr24
Lighting
04-15-05 05:08 AM
Quick Reply: GS400 HID turning purple? 3 questions
