my low beams look like tunnel vision
Can anyone help me out with this one... I replaced the low beams and the projectors cut off the light so it looks like I have eyelids or tunnel vision.. Also how many lights do I need to change out in the gauge cluster of a 92 es 300?
Can you a post a pic of the headlights (preferably at night with a wall shot)? This should provide us with the info needed to give proper info on fixing the "problem"
here is some of the pix, sorry I didn't really know how to upload them
https://www.clublexus.com/gallery/sh...=94891&cat=506
https://www.clublexus.com/gallery/sh...=94890&cat=506
https://www.clublexus.com/gallery/sh...=94889&cat=506
https://www.clublexus.com/gallery/sh...=94887&cat=506
Looks normal to me. When you have projectors, you will see a focused bright spot of light on the outer lens of the headlight right in front of the projector.
As the light gets farther away from the source, it will spread out wider.
You might want to upgrade your lightbulbs though. They look a little weak.
Looks like one side is brighter than the other.
Former Vendor
some say the left side is "supposed" to be dimmer but I disagree. You can adjust the bulb inside the housing slightly and if you move the bulb's position you'll be able to see the light output increase or decrease depending on the location within the projector housing. If you're interested in evening out the light output, fire up the bulbs and move the left bulb around up and down. Once you get the output you want, lock it in place with the metal tab.
Or - of course, just go with an HID conversion kit!
You'll notice a phenomenal difference.
