Are these reals?
Are these reals?
Are these denso ballast real?
http://www.hidexpert.com/d4s/D4S&%20...s/DSCN4321.JPG
I called Toyota and Lexus dealership and they said the part number on the ballast is no good.
no... has nothing to do with it...
a ballast is a ballast is a ballast... and i'm not surprised that there are ballast numbers that aren't listen in my EPC... those are prolly ballasts that aren't sold separately from the whole headlight assembly...
They are real. I have a set. If you look closely, they are D4S/D4R ballasts.
They just look different from most that you see because they are a newer, slimmer version of the Denso/Koito ballast.
Hey LXMN when you did the install of the HIDexpert kit, it was plug and play out of the box, I just got one as well, do you ballasts make a buzzing noise when the car is off and a quiter buzz when the car is on?
also did you change any fuses or upgrade anything else to support the upgrade?
