RX Projectors
RX Projectors
is it possible to put the RX350 projectors into the SC bezel if i were to retrofit it, i'm pretty unfamiliar with how it works but my mom has one and i turned it on the other day and its SICK how good the cutoff is and how when you turn it on the lights move back and forth.
i just want to know if thats possible on an SC bc that would be an awesome look
the Rx350 projectors are pretty big, and hard to mount because they are AFS.
once you take the AFS unit off, the projector is just an enclosed little ball basically and doesnt allow for easy monting like other projectors.
Other pojectors have mounting holes and brackets, but the afs RX330/350 do not without their AFS assembly.
There are the older rx330 projectors that are not AFS, these are pretty easy to mount, but they do have different output, I do not think it is as good as AFS units, but still are a good alternative.
but hey anything is possible. If I were you I would go with TSX projectors, they are easier to mount, have clear lenses, and they have just as good if not better output.
although RX330 projectors with clear lenses are quickly becoming a very sought after projector (have to find clear lenses to put in projector lens, as they do not come with clear lenses OEM.)
