Best place to get quality HIDs?
I have been looking at HID Planet but they won't return my emails.
I am looking for something simple that I can install on my own - plug and play - but dont want crappy quality. I am not interested in spending a little less at THE BAY to end up with not so hot quality.
Please let me know where I can find what I am looking for. Thanks for your time!
Personally I'm not a fan of the bmw projectors, however I am doing a tsx retrofit on my headlights. It's not difficult at all and once you have the projectors and HID kit, the rest is chump change and elbow grease. Make sure when you order your HID kit, you get a 9006 harness and the correct bulb for your retrofit projector (usually d2s). I'll post pictures once I'm done.
cost for me was:
$150 shipped for a pair of TSX projectors on ebay
$180 shipped for a 6000k 9006 kit with D2S bulbs
$1.50 of scrap acrylic at lowes
$2.00 of bolts, washers and nuts
$10.00 on rubbing, polishing compound to clean the headlight housings, 2000 and 1500 grit to deline and smooth out the headlight covers.
It takes a little while, but not very difficult. You'll need a drill and dremel to cut the acrylic to make an adaptor plate that fits the tsx and sc300 housing together.
cost for me was:
Are there any options that don't include the hand cutting acrylic? I am not really skilled in such a process.
Can I just use my stock projectors? Or purchase some that just bolt in and replace mine?
go ahead and use the stock projectors if you want to have a beam pattern all over the place.
the best way to do this is to do exactly what gario just told you, TSX projectors are a popular replacement for ours when retrofitting.
i personally am not skilled at it either, so either figure it out yourself doing it the same way or spend the extra bucks to have someone else do it and save yourself some frustration, its your call.
there is no shortcut though if you want to do it right
cost for me was:
cost for me was:
I am in Sacramento, CA and wondering if there is a shop nearby that will do it or a member here with some experience that is willing to do it for a fair price??
Mortgage Slave
While a PnP kit basically does the job I should have saved up a bit more and did a D2S proper retrofit instead. I don't have much of a problem with my cut off BUT the output of a dedicated D2S system seems a lot clearer and brighter than a PnP kit.
Were HIDs a manufactured option on the SC's? If so, did they use the same stock projectors? Does the dealership offer the upgrades?
If all that is possible, how do they compare to the retrofits that others are doing? Same, better, or worse quality?
no HID's ever came stock and it is impossible to upgrade through dealer
Since you're willing to spend some extra cash, then you can also ask/pay some CL members (who have done it) to do the job for you. It doesn't hurt to try. Send them PM and tell them your request.
Check the lighting forum, there are some guys posted their HID retrofit mod.
