LED size for map lights and visors for GS
EV ftw!!!
5% Club. Killing it!!!
There are three types of #74 LEDs, which one did you get and how was the buying process? I think shipping for even 1 or 2 is $5 right?
Those #74 LEDs with the twist lock base are the ones i'm wondering about if they could replace the bulbs behind the stereo and a/c unit. Has anyone done this?
Well it said 74 so i bought it. It was at the bottom of the page on the website.. I ordered last night and they shipped it out today..
Yes shiiping was 5.00.
Here's the link to one i ordered.. Its the very bottom light...
http://www.superbrightleds.com/cgi-b...e/commerce.cgi
I purchased all of my LED's from superbrightleds.com, the transaction was smooth, no problem what so ever. I'm pretty happy with them, although I am interested in a dome light that is a little brighter. How hard is it to replace the A/C and stereo lights?
I should be getting my footwell lights either today or monday.. This is my first transaction with them and they shipped it out the next day.. I think the stereo lights and A/c lights would look good.. I'm sure there pretty small like the #74's.. Keep us posted if you find anything..
TOny
I'm about to re-do my front domelights/map lights over.. They are LED's right now but their not bright enough. I'll keep you posted on what i do..I see 48 LED's going in
The ignition/footwell/shift are all #74. These
I'm one of those guys.... the things you can do with a dremel tool.. The rear has 24 LED's on each side.
wow that looks really bright.. Those are the same #74's that i ordered..
EV ftw!!!
The LED unit pictured above has only 24 LED's. How did you get 48 in there Gsoup? Did you put in two of those units?
EV ftw!!!
Easy
Hi, I've taken out the head unit several times to change out the original bulbs. It's a pretty easy process but you just gotta be careful not to strip the cable in the stereo system. It's a very small bulb. The closest LED on superbrightleds.com would be the twist lock base with #74 bulb but from my measurements compared to the measurements that they've posted, our original bulbs are a bit smaller in width, and height. If anyone has bought any of these LEDs can you confirm if it fits right. I'm afraid that the back end of it will stick out too far and the bulb might not fit through the original holes.
-John
http://www.superbrightleds.com/specs/74_t15.htm
