HID installed now having a HEADLIGHT problem!!!!! help
i recently got my 6500k hid fog kit installed from xenondepot
everything looks GREAT..but
for some reason on start up and for the first 30 sec or so it seems like my headlights are flickering
could someone please explain to me why this may be happening?
if it were my fog lights i would question maybe something not being grounded properly, but its the head lights so...
thanks in advance for your inputs
well i looked again when they were flickering and noticed it was the bulb on the passenger side.
they stay on after about 30 sec.
i forgot to note that i purchased new 6000k hid bulbs from xenonvolent a month ago.
do you think that bulb is burning out already!?!?!
You know what mkim1120... i got my HID kit last week and mine do the EXACT same thing... mine are 8000k though, i dont think it makes a difference... im anxious to know what could be causing the flickering, and yah they do it about 30 seconds after power-up but mine both flicker one at a time...
b/c i installed a fog light kit and now my head light bulb is flickering
the hid kit for the head lights are stock and i just replaced the bulbs from 4300k to 6000k
oh no, I have some cheap 12volt aftermarket fogs, I bought a 8000k color temp HID headlight kit with the 9006 headlight bulbs... so not the hid fogs
I just changed my stock HID's from 4300K to 6000K from xenon valot and they flicker for the first 30 seconds but then become stable. HELP!!!!!
__________________
2007 Lexus IS 250 RWD | SGM with Black Interior
Premium Package w/ 18" wheel with Navi | 6000K Xenon Valot with AFS |Xenon Depot Xtreme 6500K Fog Lights| Tinted Windows | Red-Out Taillights | Nav Hack | Vasitech ipod adapter
__________________
ok well how about this. i have the stock '05 rx330 HID lights. my passeger side HID bulb is out. i tried switching the bulbs from the driver side just to make sure it was the bulb. and its NOT the bulb. so i put the good bulb back on the driver side and i turn my lights on to make sure it works on the driver side, and i notice all the rest of the lights on the passenger side flickering. could it be the ballast? is that why my HID bulb is out?
90% of the time if your aftermarket HID's flicker...then it's most likely that they are not getting enough power. You should upgrade to a relay harness if you're having that problem. The other solution is to get a more efficient ballast that can stabilize voltages better and uses less power so you can run off the stock harness.
