How big is the wedge bulb hole in the 2GS headlight?
Old 03-14-07, 07:29 PM
GSteg
GSteg's Avatar
set your camera for longer exposure (if you're using a digital camera that allows changing exposure) They dont look too bad.
When you retro'ed the projectors in, did you have to shave off the headlight's shroud a bit?
Old 03-14-07, 07:34 PM
chrispy
chrispy's Avatar
I'll try that and get back to you but I shouldn't even be on CL right now.
Remember when we talked on AIM a while ago? I showed you a picture of the shroud and it was cut by whoever I bought it from. They cleared everything after I shaved the turn signal part a bit. So they look like they stick out enough?
Old 03-14-07, 07:41 PM
GSteg
GSteg's Avatar
Oh yea I forgot about that.
Look at your car from the side. Your head should be about headlight level. Are you able to see the projector lens from that view?
Old 03-14-07, 11:39 PM
chrispy
chrispy's Avatar
Yeah, I can see shroud sticking out and the projector lens is not covered. I might swap some 4300k bulbs in to see if there is a difference.
Old 03-15-07, 10:02 AM
o2GS43o
o2GS43o's Avatar
Originally Posted by pingu
That is really small. You may have some issues fitting a large bulb in there. I know people have had issues with the Polarg M6's. Since you are in CA you may have cop problems if you replace the wedge with LEDs. Im considering switching back to stock bulbs after some recent hassles. What ever you do good luck.
I have Polarg M4's and cops have not give me probs yet... hopefully they don't...
Old 03-15-07, 04:56 PM
pingu
pingu's Avatar
I think it really depends on where in Cali you live. If you live in the so cal area where the tuning scene is huge then I would say you have more of a risk. I was hassled in the parking lot twice and it wasnt even a car meet. They noticed that my parking lens' were white and not orange. I personally think the M4's look more blue then white. I may try the M6's but the bulb draws more current.
Old 03-15-07, 05:13 PM
MrG4Life
MrG4Life's Avatar
The polargs looks white from a far distance. As long as the color is not super obvious red or blue, then everything will be fine. Never have I been pulled over for it. It somewhat matches my HID and my HIDs are OEM temperature. Loose close enough
Well if I was living there in Cali (or anywhere else) then I need not worry since my the bulbs light output look somewhat alike. Nothing obvious as u said.
Ken167
09-10-16 02:43 PM
rns
03-10-16 01:34 AM
DJVe
SC- 1st Gen (1992-2000)
06-01-11 11:39 AM
mo12hammad
09-07-09 04:06 PM
zirrall
04-27-05 10:07 AM
Quick Reply: How big is the wedge bulb hole in the 2GS headlight?
