HID recommendations?
well... i had this installer put in these japanese HID kit about 2 years ago... and its crapping out on me... we switched the ballast a couple of times but it still craps out...
now he's proposing to put in a different brand, but i don't trust him!!!
what brand HID should I be looking into? thanks
Former Vendor
**************** sells klight brand HID kits. most klight distributors offer klight kits without a wire harness that connects directly from the battery to the ballasts. the klight ballasts are powered directly from the factory electrical system which is VERY bad for your electrical system.
believe me - i've tested out my fair share of HID kits...
![](http://mobilehid.com/ballasts.jpg)
i did an install on a bmw 540i where the guy said his factory bulb plugs fit the ballasts perfectly and he insisted on not using the included wire harness that came with his kit. after we hooked it up, his dash lights, the power seats, the turn signals, cabin lights all stopped working. needless to say, i went ahead and wired up the wire harness for a direct connection to the battery and sent him to the dealership for diagnosis immediately after.
philips is good stuff but it comes at a high price... i picked up a philips kit from xenondepot.com a couple of years back and the bulbs that came with it produced A TON of glare. since then i picked up 2 kits from a diff manufacturer that i run in my lows and fogs and the results are fantastic. less glare, the bulb is constructed closer to the 9006 spec.
see below:
![](http://www.mobilehid.com/bulbs.jpg)
whatever kit you buy- make sure it has a wire harness with a relay and fused wired inline.
see below:
